TABLEEXPORT command
TABLEEXPORT command
Exports the contents of a table.
Method
Exports the contents of a table to a CSV or XML file, through the Export Data dialog box.
Note: The CSV file can be imported into spreadsheet and database programs to format and further process the data.
Parent topic: Riferimento Comandi
  • TABLE command
  • -TABELLA
  • TABLEMOD command
  • MODIFTABELLA
  • TABLESTYLE command
Related Information
  • Lavorare con le tabelle
