TINMERGE command
Combines two or more TIN surfaces (or gradings) into a new TIN surface.
Icon:
Combines a base surface and two or more other TIN surfaces to merge with, which will replace the part of the base surface that it covers.
Methods
Select a base TIN surface and one or more TIN surfaces to merge with, and specify if you want to keep or delete the original surfaces.
Options within the TINMERGE command
- Removal of original surfaces
- Yes
- The original surfaces are deleted. This options results in a merged TIN surface that cannot be edited.
- NO
- The original surface to merge is not deleted. This option results in 2 TIN surfaces:
- Original TIN surface to merge
When selecting and moving this surface, the merged TIN surface changes accordingly.
- Merged TIN surface.
