TINEDIT command
Allows editing a topographical surface (TIN surface).
Icons:
Allows you to add or remove points or point groups on a TIN (triangulated irregular network) surface. You can add breaklines and boundaries.
Pick points and specify their elevation value to add them to an existing TIN surface or choose another option in the Command line.
Options within the command
- Add Points
- Sets points or linear entities to add to a TIN surface.
- Add Point Groups
- Enables you to select point groups to add to a TIN surface.Note: Civil point groups need to be defined first.
- Add Breaklines
- Sets linear entities to be added as breaklines to a TIN surface.
- Add bOundaries
- Sets a closed polyline as boundaries to add to a TIN surface.
- Remove Points
- Deletes points from a surface.
- Swap Edge
- Deletes a selected edge of the surface.
- Point Location
- Allows you to modify a point location by specifying the point to edit location and the new location.
- Point Elevation
- Allows you to modify a point elevation by specifying a point and entering a new elevation value.
- Add Line
- Allows you to add a new line by specifying the first point and the second point.
- Delete Line
- Deletes lines covered by a selection window.Note: The lines to be deleted are displayed in red.
- Remove Outer Edges
- Removes edges that do not correspond with the entered characteristics.
- Maximum triangle length
- Minimum triangle length
- Maximum angle
