Using the Library panel in the Mechanical workspace
About
The Library panel (
) provides quick access to your Mechanical blocks and predefined items. You can add any CAD model to the Library, customize its name and category for easy retrieval, and insert blocks into your drawing by dragging and dropping.
- Uruchom polecenie BIBLIOTEKAOTWÓRZ.
- Kliknij prawym przyciskiem myszy panel wstążki lub pasek narzędzi i wybierz Biblioteka z listy Panele.
Content of the Library panel
You can control the content of the Library panel in the Menu.
Searching the block libraries
Type a search string in the search field to display blocks matching your query in the current category.
Inserting a hex head bolt into your 3D model
This method can be used for most of the blocks in the Library panel.
You can edit the dimension of the bolt during or after the insertion process (via the Properties and Mechanical Browser panels).
- Click the .
- Click a bolt thumbnail from one of the folders in the panel.
- Hover the cursor over the Model Space and click when in the desired position.
- If Dynamic dimensions (DYN) is switched on, set the bolt location by entering the dimensions into the DYN fields. Press the Tab key to cycle through the DYN fields. A DYN field turns red to indicate the distance is locked.
- Press Enter. The bolt is inserted.
- (Optional) To adjust the dimensions of the bolt after it has been inserted, go to the Mechanical Browser panel. Select the bolt, scroll down to the Parameters section and change the parameters as required.
Working with Mechanical blocks
The value of Type property for all blocks in the Bricsys Mechanical library is Mechanical block. These blocks behave similarly to regular blocks.
Use the CONVERTCOMPONENTSTOBLOCKS command to convert Mechanical Components (deprecated) to Mechanical blocks.
Edit Mechanical blocks with the BEDIT command and replace them with the BLOCKREPLACE command.
Tworzenie bloku biblioteki
Aby utworzyć blok biblioteki, otwórz lub utwórz rysunek zawierający geometrię nowego bloku, a następnie otwórz panel Biblioteka.
- Wybierz biblioteki, które chcesz wyświetlić, z menu panelu.
- Naciśnij przycisk dodawania
lub uruchom polecenie UTWÓRZBLOKBIBLIOTEKI.Zostanie wyświetlone okno dialogowe Dodaj blok do biblioteki.
- Zaznacz podmioty lub wybierz opcję Cały rysunek.
- Wpisz nazwę bloku.
- (Opcjonalnie) Wpisz nazwę nowej kategorii lub wybierz kategorię z listy.
- (Opcjonalnie) Kliknij Pokaż opcje i ustaw opcje tworzenia bloków.
- Kliknij przycisk Utwórz .
Managing user library blocks
- Hover over the block thumbnail.
- Click the Menu icon.
- (Optional) Click the File Open icon to open the block file.
Edit the file, then save the changes.
- (Optional) Click the Delete icon to delete the block file.
Click Yes to confirm.
