-ADDLINECURVELABELS command
Adds labels along curves or lines via Command line.
Creates labels for lines, polylines, 3D polylines or Civil string entities via the Command line.
Method
Select the label type (line and curve or between two points), enter the label style names, then select the entities to add labels to.
Options within the command
Line and curve
Adds the line labels between the start and end point of the line.
Between two points
Adds the line labels between two specified points.
