-LAYOUT command
Creates a new Layout tab via the Command line.
Creates a new Layout tab in the drawing via the Command line and sets the page and plot settings.
Options within the command
? to list
Lists the names of layouts already defined in the drawing.
Set
Switches to the specified layout.
New
Creates new layouts.
Copy
Creates a new layout by making a copy of an existing layout.
Delete
Erases layouts from the drawing.
Rename
Renames layouts.
SAve
Saves the mentioned layout as DWG or DXF files format.
Template
Imports layouts from DWG, DWF or DXF drawing files.
Specify the file name and the layout names.
neXt
Displays the next layout.
Previous
Displays the previous layout.
