SPHERE command
Creates a 3D Solid in the shape of a sphere.
                Icon:
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the
                    SPHERE command launches the AI_SPHERE command.
Creates a 3D Solid in the shape of a sphere. Choose from a combination of options
                including center, radius and diameter.
                    - Center
 - Radius
 - Diameter
Method
This command has 1 method to begin creating a sphere:
- Center of sphere
- Center of sphere
 - Begin creating a sphere by specifying the center then:
 - Set radius of sphere
 - Specify the radius of the sphere.
Option within the command
After you begin creating a sphere, the following option may be available:
- Diameter
 - Specify the diameter of the sphere.
