BDEPENDENCYHIGHLIGHT system variable
Highlight dependent objects
Highlights all objects that are dependent on a selected action or parameter in the Block Editor.
Wpisz:
Boolowskie
Zapisano w:
Rejestr
Domyślna wartość:
Na
Możliwe wartości:
Off (0): Dependent objects are not highlighted when an action or parameter is selected.
On (1): Dependent objects are highlighted when an action or parameter is selected.
