SHEETSETHIDE command
Closes the Sheet Sets panel.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_INTL/command-reference-lite-pro-mechanical-bim.png)
Closes the Sheet Sets panel to hide it from the current workspace. If the Sheet Sets panel is stacked when you close it, the Sheet sets tab or icon is removed from the stack.
