Manage Vertical Alignments dialog box
Opens via: ALIGNMENTVERTICALMANAGE command
Note: The Manage Vertical Alignments dialog box opens immediately if a horizontal alignment is already selected in the drawing. Otherwise, it opens after you select a horizontal alignment from the Select Alignment dialog box.
The Manage Vertical Alignments dialog box allows you to create or delete vertical alignments.
Alignment
Displays the horizontal alignment name.
Add surface vertical alignment button
Opens the Add Surface Vertical Alignment dialog box to add a surface for a vertical alignment.
Vertical alignments
Lists the vertical alignment objects created.
Object
Lists the vertical alignment objects grouped by source type (for example, Surface or Layout).
Update mode
Displays how the vertical alignment updates when its source changes.
Data source
Displays the source used to create the vertical alignment.
Start station
Displays the start station of the vertical alignment.
End station
Displays the end station of the vertical alignment.
Actions
Allows you to delete a vertical alignment from the list.
