-DIMSTYLE command
Creates and modifies dimensions styles at the Command line.
Icon:
Alias: -DST
Method
Run the command to create a new dimension style by choosing one of the options. The command also prompts the name of the current dimension style.
Options within the command
- Lists the names of all dimension styles loaded into the current drawing, other than Standard.
- ANnotative
- Sets the annotative property of the dimension style.
- Apply
- Changes or restores the style of existing dimensions by applying the current style.
- Save
- Saves the current dimension settings as a style.
- STatus
- Displays the current value of every dimension variable.
- Variables
- Lists the values of dimension variables belonging to the selected dimension.
- Restore
- Resets the values of dimension variables to those of the selected dimension.
