AI_PYRAMID command
Creates a 3D polyface mesh in the shape of a pyramid.
Icon:
Creates a 3D polyface mesh in the shape of a pyramid with three or four sides. The sides of the base may have unequal lengths. Options allow you to specify a pointed, ridged, or flat top.
Methods to create a pyramid
There is one method to begin creating a pyramid
- First point for the base of pyramid
- First point for base of pyramid
- Begin creating a pyramid by specifying a corner for the base of the pyramid then:
- Second point
- Specify the second point of the base.
- Third point
- Specify the third point of the base.
- Set last point for base
- Specify the fourth point of the base.
- Set apex of pyramid
- Specify the location for the top of the pyramid.
Options within the AI_PYRAMID command
After you begin creating a pyramid, the following options may be available:
- Tetrahedron
- Choose this option to finish creating the base of the pyramid after specifying the third point to create a three-sided pyramid (tetrahedron) then:
- Set apex of tetrahedron
- Specify the top of the tetrahedron.
- Ridge
- Specify the start and end points to create an edge at the top of the pyramid.
- Top surface
- Specify four points to create a face at the top of the pyramid.
