ALIGNMENTLINE command
Creates unconstrained line element between two specified points on existing or on a new Horizontal Alignment.
Icon:
Method
There are two options:
  • Create a new line element between two specified points on existing horizontal alignment.
  • Create a new alignment by drawing a line element between two specified points.
Options within the command
Select existing horizontal alignment
The new unconstrained line element is created on selected existing Horizontal Alignment, between two specified points.
Note: First select the existing horizontal alignment in the drawing, and then specify the first and second point, between which a new line element is created. You can then continue drawing new line elements on existing horizontal alignment until you press the Enter key.
Create new alignment
Creates new Horizontal Alignment by drawing a line element between two specified points.
Note: Specify the first and second point in the drawing, between which a new line element is created. You can continue drawing new line elements until press the Enter key.
