ALIGNMENTEDIT command
Edits an alignment.
Icon:
Method
Select a Horizontal or Vertical alignment to edit.
Options within the command for Horizontal alignment
Continue with Pi
Allows you to continue the Horizontal alignment.
Note: This option works only if the last element is fixed line.
Delete Element
Allows you to delete alignment elements.
Add Pi
Adds a Pi Point to the alignment.
Remove Pi
Removes a Pi point.
Add Station equation
Allows you to add station equation.
Remove Station equation
Allows you to remove station equation by specifying the index.
Options within the command for Vertical alignment
Add Pvi
Adds a Pvi point to the alignment.
Remove Pvi
Removes a PVI point.
