ARRAY command
Creates an array of entities.
Icon:
Alias: AR
Creates a polar or rectangular array, or along a path of entities through the command line.
Note: Arrays can be created using 2D or 3D entities.
Methods
There are three methods to create an array of entities:
  • Rectangular
  • Path
  • Polar
Note: The default array type is saved by the ARRAYTYPE variable.
Options
Rectangular
Distributes entity copies into any number of rows, columns and levels (on Z direction).
PAth
Distributes entity copies evenly along a path into multiple rows and levels.
POlar
Distributes entity copies evenly in a circular pattern about a center point or axis of rotation, using multiple rows and levels.
