DIM1 Command
Executes a single dimension command at the 'Dimensioning command:' prompt.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Allows to create a single type of dimension, as specified in the Command line.
Options within the command
- HORizontal
- Places horizontal linear dimensions, same as the DimLinear command.
- VErtical
- Places vertical dimensions, same as the DimLinear command.
- ALigned
- Places linear dimensions that are aligned to entities, same as the DimAligned command.
- ANgular
- Places angular dimensions that measure angles, same as the DimAngular command.
- Leader
- Places leaders, same as the DimLeader command.
- OBlique
- Changes the angle of extension lines, same as the DimEdit command.
- ROtated
- Places linear dimensions at an angle, same as the DimLinear command.
- CEnter
- Places marks at the centers of circles and arcs, same as the DimCenter command.
- Diameter
- Places diameter dimensions on circles and arcs, same as the DimDiameter command.
- RAdius
- Places radial dimensions on circles and arcs, same as the DimRadius command.
- Baseline
- Places multiple linear and angular dimensions from the same base point, same as the DimBaseline command.
- COntinue
- Continues linear and angular dimensions from the last endpoint, same as the DimContinue command.
- ORdinate
- Places x and y ordinate measurements from an origin point, same as the DimOrdinate command.
- Position
- Repositions the dimension text, same as the DimTEdit command.
- DIStribute
- Spaces selected dimensions equally. There are two options between which to chose how the dimensions will be distributed.
- Equal
- Distributes equally all the dimensions selected.
- Offset
- All selected dimensions are distributed at a specified offset distance.
- UPdate dimensions
- Applies the current dimension style to a selection of dimension entities; see Apply option of the -DimStyle command.
- variable STatus
- Lists the status of all dimension variables in the Prompt History window.
- OVerride
- Overrides the values of the current dimension style, same as DimOverride command.
- SEttings...
- Opens the Drawing explorer | Dimension styles dialog box which allows you and modifying dimension styles, same as the DIMSTYLE command.
- LAyer
- Sets a different layer for the default layer on which dimensions are draw.
