Creates a dimension that aligns with the origin points of the extension lines. The
dimension is based on the current dimension style. Options allow you to specify the
angle and contents of the dimension text.
Note: Isometric view can be dimensioned and reflect
the actual true geometry size.
Methods to create an aligned dimension
This command has 2 methods to begin creating an aligned dimension:
Origin of first extension line
Select entity
Begin creating an aligned dimension by specifying a point for the first
extension line then:
Origin of second extension line
Specify a point for the second extension
line.
Location of dimension line
Specify the location of the dimension line. The
dimension is placed at the same distance from each of the extension line
origins.
Additional options: [Angle/Text]
Aligned dimension
Select entity
Begin creating an aligned dimension by pressing Enter then:
Select entity to dimension
Select a line, polyline segment, arc, or circle to
dimension. When selecting a line, the endpoints of the line are used for
the extension origins. When selecting an arc, the endpoints of the arc
are used for the extension origins. When selecting a circle, the
selection point on the circle is used for the first extension origin and
the opposite point on the diameter of the circle is used for the second
extension origin.
Arc entity
Selection point of circle entity
Polyline entity
Additional option: [selection options (?)]
origins.
Options within the DIMALIGNED command
After you begin creating an aligned dimension, the following options may be
available:
Angle
Specify the angle of the dimension text. A value of 0 aligns the
dimension text with the dimension line. Any other value rotates the
dimension text relative to the x-axis of the current UCS.
Text
Enter text to override the default dimension text which includes the
measured length of the dimension. You can use two angle brackets
<> to display the measured length of the dimension in addition to
other text.
