DIMTEDIT command
Changes the position of dimension text.
Icon:
Alias: DIMTED
Allows you to change the position and angle of the text within a dimension entity.
Methods
This command offers four methods to change the position of dimension text.
  • Rotate the dimension text.
  • Move the dimension text to the left.
  • Move the dimension text to the right.
  • Center the dimension text.
Options
Angle
Rotates the dimension text from the original dimension text position (1) to the rotated dimension text position (2).
Left
Moves the dimension text next to the left extension line of the dimension, depending on the original positioning of the dimension.
Center
Centers the dimension text between the two extension lines of the dimension.
Right
Moves the dimension text next to the right extension line of the dimension, depending on the original positioning of the dimension.
REstore
Resets the rotation angle of the dimension text to 0 degrees and does not change repositioned dimension text.
