DMAUDITALL command
Analyzes and repairs errors in drawings inserted as external references
It is a powerful tool to analyze and automatically fix problems in 3D geometry supported by ACIS kernel (3D solids, surfaces).
Note: It is recommended to run DMAUDITALL whenever 3D geometry is imported.
Method
There are two methods to audit the drawing:
  • Check problems.
  • Fix problems.
Options within the command
Check
Checks the 3D geometry in the drawing for errors without fixing them.
Fix
Repairs errors.
Back
Returns to the main prompt of the command.
report Panel
Redirects the output of the command to the Report panel.
Note: Depending on the value of REPORTPANELMODE variable, it might be necessary to click on the red exclamation mark in the lower right corner to see more details in the Report panel.
copy to File
Reports the output of the command in a file.
audit Level
Sets the strictness of the check.
Low
Runs basic analysis (for example, catching common fatal topology errors).
High
Goes deep (for example, catching self-intersections in solid bodies).
Medium
This is the default level.
Coincident faces
Checks and fixes coincident faces. Requires audit level set to High.
