GRADING command
Creates a graded surface on existing TIN surfaces.
Icon:
Creates a graded surface between a selected entity and a TIN surface or an offset or slope graded surface from a selected entity. Select the entity to define a graded surface, select the target TIN surface to create a graded surface and move the mouse to adjust the slope of the grading.
Method
Grading can be created along the entire length of the selected input entity or between specified start and end point.
Note: Gradings also support transitions.
Options
- slOpe/offset
- Sets either the slope or offset option of the grading.
Note: The offset-slope projection method requires input
entity, offset, and slope.
- Entire length
- Creates a grading using the entire input entity.
