GRADINGBALANCE command
Balances grading cut and fill volumes.
Icon:
Balances grading cut and fill volumes within the specified tolerance. This is achieved by raising/lowering the elevation of the grading input entity and the result is grading that has a net volume around zero, depending on the set tolerance.
