LAYON command
Turns on all layers in the drawing.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Turns on all layers in the drawing to view and edit entities on those layers.
There are no prompts. The Command line indicates: all layers have been turned on.
Note: Entities on frozen layers are only visible if you also thaw
the layer. Entities on locked layers are only editable if you also unlock the
layer.
