LAYULK command
Unlocks the layer of a selected entity.
Icon:
Unlocks the layer of a selected entity to enable entities on that layer to be edited.
Method
You are prompted:
Select an entity on the layer to be unlocked
Select an entity on the layer you want to unlock. The Command line indicates which
layers have been locked:
- This layer has been locked: LayerName1
- This layer has been locked: LayerName2
