LAYULK command
Unlocks the layer of a selected entity.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Unlocks the layer of a selected entity to enable entities on that layer to be edited.
Method
You are prompted:
Select an entity on the layer to be unlocked
Select an entity on the layer you want to unlock. The Command line indicates which
layers have been locked:
- This layer has been locked: LayerName1
- This layer has been locked: LayerName2
