LAYUNISO command
Restores isolated layers to their previous state.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Restores the Lock, On/Off, and VP Freeze properties of isolated layers as they were before you used the LAYISO command.
There are no prompts. The Command line indicates: Layers isolated by LAYISO command have been restored.
