LIMITS command
Sets an imaginary boundary for the extents of the drawing and optionally, of the grid.
Icon:
The command creates an imaginary rectangle boundary inside the drawing area.
Drawing outside of the area defined by this command is restricted when the LIMCHECK system variable is On. "Selected point is outside limits. Please select another point." will be reported in the Command line.
The imaginary boundary also limits the grid display when the first flag of the GRIDDISPLAY variable is not set.
Options
Lower left corner
Specifies the lower left corner of the limits.
Upper right corner
Specifies the upper right corner of the limits.
ON
Turn on the limits for your drawing area.
OFf
Turn off the limits for your drawing area.
