PDFOPTIONS command
Opens the Settings dialog box with the PDF export category expanded.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Opens the Settings dialog box with the PDF export category expanded to view and modify relevant system variables.
