TABLEDIT command
Edits text in a table cell.
Method
Edits text in a table cell through the Text Formatting window.
Note: To edit the format of cells, use the TABLEMOD command.
Note: The Text Formatting window operates the same way as the one from the MTEXT command.
Note: Error cells are evaluated as blank or zero values when used in another cell's formula.
