TINVOLUME command
Creates a TIN volume surface between a base and comparison TIN surfaces or an elevation.
Icon:
Method
When the TIN Volume Surface associativity option of the Civil / Associativity user preference is set, TIN volume surfaces automatically rebuild when their source surfaces change.
Select the base and the comparison TIN surfaces between which a TIN volume surface will be created and select a bounding area for the TIN volume surface.
Options within the command
Elevation
Creates a TIN volume surface between a base and an elevation.
Select the base TIN surface, enter the desired elevation value and select a bounding area for the TIN volume surface.
