Using the Library panel in the BIM workspace
About
The Library panel (
) provides quick access to your BIM blocks and predefined items. You can add any CAD model, customize its name and category for easy retrieval, and insert blocks into your drawing by dragging and dropping.
- Run the LIBRARYPANELOPEN command.
- Right-click a ribbon panel or toolbar and choose Library from the Panels list.
Content of the Library panel
You can control the content of the Library panel in the Option menu.
Searching the block libraries
Type a search string in the search field.
Only matching library blocks in the current category display.
Inserting a BIM window into your 3D model
This technique can be used for most of the blocks in the Library panel.
All windows and doors in the block library are parametric. You can edit their dimension during or after the insertion process (via the Properties panel).
- Click the Windows category tile in the Library panel.
- Click a window thumbnail in the panel.
- Hover the cursor over the wall in Model Space and click when in the desired position.
Note: You can also insert windows and doors when you are in Top View Mode. For Top View Mode info, see the The Story Bar article. - If Dynamic dimensions (DYN) is switched on, set the window location by entering the dimensions into the DYN fields (1). Press the Tab key to cycle through the DYN fields. A DYN field turns red to indicate the distance is locked.
- Press Enter. The window is inserted.
- (Optional) To adjust the dimensions of the window after the window has been created, go to the Properties panel. Scroll down to the Parameters section and change the parameters as required.
- (Optional) Once you have a window, you can adjust the position by selecting the window and then clicking the dimension lines and editing the dimensions (2).
Note: A red preview appears while a solid with a subtractor, such as a window, is copied, moved, or manipulated, ensuring easy placement on the affected solid.
Working with BIM blocks
The value of Component type property for all blocks in the Bricsys BIM library library is BIM Block. These blocks behave similarly to regular blocks.
Use the CONVERTCOMPONENTSTOBLOCKS command to convert Mechanical Components (deprecated) to BIM Blocks.
Edit BIM Blocks with the BEDIT command and replace them with the BLOCKREPLACE command.
To create a BIM Block, use the BIMCLASSIFY command with the Drawing selection option, then the CREATELIBRARYBLOCK command to add it to the components library.
Creating a library block
To create a library block, open or create the drawing which contains the geometry for the new block, then open the Library panel.
- Select which libraries to display from the panel menu.
- Press the Add button
or launch the CREATELIBRARYBLOCK command.The Add block to library dialog box displays.
- Select the entities or choose the Entire drawing option.
- Type a name for the block.
- (Optional) Type a new category name or choose a category from the list.
- (Optional) Click Show Options and set the block creation options.
- Click the Create button.
Managing user library blocks
- Hover over the block thumbnail.
- Click the Menu icon.
- (Optional) Click the File Open icon (1) to open the block file.
Edit the file, then save the changes.
- (Optional) Click the Delete icon (2) to delete the block file.
Click Yes to confirm.
