Editing block definitions in the Block Editor
You can access the Block Editor with the BEDIT command or by double-clicking on the block you wish to edit. When using the Block Editor, BricsCAD displays the block entities in a temporary drawing session. It includes all the tools you need to create and edit a block definition.
To exit the block editing session, use the BCLOSE command and choose whether to save or discard the changes.
You can use the BSAVEAS command while in the block editing session to copy the current block definition to a new name. Call the command at the Command line or click the icon in the Ribbon.
If you use the SAVE command while in the block editing session, BricsCAD saves the changes to the block definition and exits the Block Editor.
Use the BESETTINGS command to access the Block Editor settings section of the Settings dialog box.
Blocks can also be edited using the REFEDIT command.
