Choosing the workspace
The default workspaces are:
  • 2D Drafting, which requires a BricsCAD Lite or higher license level.
  • 2D Drafting (Modern), which requires a BricsCAD Lite or higher license level.
  • Modeling, which requires a BricsCAD Pro or higher license level.
  • Civil Survey, which requires a BricsCAD Pro or higher license level.
  • BIM, which requires a BricsCAD BIM or BricsCAD Ultimate license level
  • Mechanical, which requires a BricsCAD Mechanical or BricsCAD Ultimate license level.
  • Ultimate, which requires a BricsCAD Ultimate license level.
The current workspace configures the overall layout of the BricsCAD application window.
A workspace defines the content of:
  • Menus
  • Toolbars
  • Panels
  • The ribbon
  • The Quad basics
You can set the current workspace in:
  • The Start page.
  • The Current Workspace field in the Status Bar.
  • The Workspaces toolbar.
  • The WORKSPACE command.
  • The BricsCAD Setup (Only for trial).
