The BricsCAD application window
| Item | Element | Description | Visibility |
| 1 | Title bar | Displays the application name and the current license level. | Always displayed. |
| 2 | Menu Bar | Provides access to the main menus. The content of the menu is defined in the current workspace. | Hidden by default in all workspaces. Right-click a toolbar, the Ribbon or a panel, and choose Menu Bar. Alternatively, set the MENUBAR system variable. |
| 3 | Toolbar | Groups related commands as icons for quick access. A toolbar can float or dock to any edge of the application window. | Run the TOOLBAR command. Alternatively, right-click a toolbar, the Ribbon or a panel, choose Toolbars, and select the toolbar. |
| 4 | Ribbon | Displays tabbed sets of tools, grouped by functionality. | Run the RIBBON or RIBBONCLOSE command. Alternatively, right-click a toolbar, the Ribbon or a panel, choose Panels, and select Ribbon. |
| 5 | Document tabs | Switches between the open drawings and the Start page. Click the + button to create a new drawing. | Set the SHOWDOCTABS system variable. |
| 6 | Panels | Displays the active panels. Click an icon to open the associated panel. | Run the specific command to open or close the panel. Alternatively, right-click a toolbar, the Ribbon or a panel, choose Panels, and select the panel. |
| 7 | Drawing area | Contains the drawing and the tools to create and edit it. | Always displayed. |
| 8 | LookFrom control | Switches between preset view orientations. | By default, the LookFrom control is displayed in the top right corner of the graphic screen |
| 9 | Scroll bars | Pan the drawing. Hidden by default. | Press Shift+F4 or run the SCROLLBAR command. |
| 10 | UCS Icon | Indicates the orientation of the current User Coordinate System (UCS). | Set the UCSICON system variable. The UCSICONPOS system variable defines the position of the icon. |
| 11 | Command Line | Displays prompts and a field to enter commands. | Run the COMMANDLINE or COMMANDLINEHIDE command. Alternatively, right-click a toolbar, the Ribbon or a panel, choose Panels, and select Command Line. You can also press Ctrl+9 or Shift+F2. |
| 12 | Status Bar | Displays the model and layout tabs, and the drawing tools with their current status. | Right-click a toolbar, the Ribbon or a panel, and choose Status Bar. |
Interface Settings
The Interface Settings button is located at the top-right corner of the Ribbon. The RIBBONSETTINGSENABLED system variable controls whether the button is displayed or not.
The Interface Settings dialog box manages the interface display of your BricsCAD workspace. See the Interface Settings dialog box related article.
The color theme
The COLORTHEME system variable sets the color theme for the Ribbon, panels, dialog boxes, etc. You can choose between a dark or a light color theme.
To set the color theme, do one of the following:
- Type COLORTHEME in the Command line and choose 1 for light or 0 for dark.
- Right-click on a toolbar or Ribbon panel and select Dark Interface in the context menu.
- Open the Interface Settings dialog box and choose a Theme.
Using the clean screen mode
The clean screen mode maximizes the drawing area by hiding user interface elements, such as the menu bar, the Ribbon, toolbars, panels, the Command line, the status bar and the document tabs. You can still use the Quad to launch commands.
To toggle the clean screen mode, do one of the following:
- Run the CLEANSCREENON command to hide the elements and the CLEANSCREENOFF command to display them again.
- Press Ctrl+0.
The CLEANSCREENOPTIONS system variable defines which user interface elements are hidden.
