-ATTEXT command
Copies data from attributes to a text file through the Command line.
Alias: -AX
Note: The template TXT file must exist before this command is used. See the ATTEXT command for the format of this file.
Method
There are two methods to use –ATTEXT command:
- Select entities: the Attribute Extract Template File dialog box displays.
- Extract as Dxf/Cdf/Sdf: the Attribute Extract Output File dialog box displays.
Options within the command
- select Entities
- Specifies the entities from which will extract attribute value.
- extract as Dxf
- Exports the attribute values in a partial DXF format.
- extract as Cdf
- Exports the attributes with commas separating values.
- extract as Sdf
- Exports the attributes in fixed-width format.
