ARRAYEDIT command
Edits associative arrays.
Icon:
Method
Select the associative array, then choose the options you want to edit.
Note: The options in the Command line differ depending on the type of associative array you selected.
Options within the command
Note: The following options are available for any array type. For more information about the options for each array type, see the:
- ARRAYRECT command article for rectangular array.
- ARRAYPATH command article for path array.
- ARRAYPOLAR command article for polar array.
- Source
Edits the source entities of the array.
Note: Displays Array Editing State dialog box. Only the selected entity is displayed in Associative Array Edit environment so it can be easy to modify, add and delete entities. The changes are applied to all the entities once the array editing state is closed.
- REPlace
- Replaces some or all the entities in the array.
- Base point
- Sets the base point of the array. Items are placed relative to the base point.
- Rows
- Specifies the number of rows, the spacing between subsequent rows and the incremental elevation.
- Levels
- Creates 3D arrays by specifying the number and spacing of levels.
- Total
- Specifies the total distance between the start and end row.
- Expression
- Uses a mathematical formula or equation to derive the value.
- RESet
Restores erased entities and removes any item overrides.
Note: Hold the Ctrl key to select more than one item in the associative array, then press the Delete key to erase the selection.
- eXit
- Accepts the changes and concludes the command.
