-BLOCKIFY command
Converts identical sets of entities (2D or 3D) to block references via Command line.
Searches the drawing for identical sets of entities (2D or 3D) and replaces them with block references.
Method
There are four methods to use the BLOCKIFY command:
- Detect matches with selected entities
- Detect matches with existing blocks
- Detect equal 3D solids
- Detect collections (of 3D solids/block references and 2D block references)
Dependent on the selected mode, different follow-up questions and advanced options are presented.
Select the desired method, source entities and search space. Set the options and tolerance as needed. The options displayed are relevant for the selected method and entities and reflect the BLOCKIFYMODE and BLOCKIFYTOLERANCE system variables settings (see the related articles).
The default mode is to detect matches with selected entities. This mode searches the drawing (or the selection) for recurring 2D/3D geometry and converts them to block references. Select the source entities, select the search space, select a block insertion point (for new block definitions) and specify a block name.
Options within the command
- match Equal solids
Searches the drawing (or the selection) for equally shaped solids and converts them to block references (new block definitions). In case a solid matches an existing block definition, the replacing block reference points to that block definition.
Note: This option is not available in the BricsCAD Lite license level.
- find Collections
Searches the drawing (or the selection) for sets of identical collections of:
- 3D solids and/or 3D block references
- 2D block references
- match existing Blocks
Searches the drawing (or the selection) for matches to existing block definitions present in the drawing and converts them to block references.
- check Library
Allows you to specify the block definitions search location.
