Command panel
A command panel offers intermediate user interaction when executing a command. The advantage of a panel compared to a dialog box is that the content of the drawing remains visible, instead of being partially blocked.
The following commands use a floating command panel:
- BIMDIMENSION
- BMBOMTEMPLATEEDIT opens BOM Manager panel
- FITARC
- FITLINE
The following commands use a Command Context panel, which is a dockable panel. It appears at the same size and location that it did before it was closed or collapsed, and like any other dockable panel, the Command Context panel can be either floating, docked or stacked.
- ARRANGE
- BIMIFY
- BIMINVERTSPACES
- BIMQUICKBUILDING
- BIMQUICKDRAW
- BIMTAG
- BLOCKIFY (Find Collections option)
- CAEANALYZE2D command
- DMAUDIT
- DMSIMPLIFY
- DMSIMPLIFYALL
- DWGHEALTH
- FINDOUTLIERS
- NUMBER
- OPTIMIZE
- POINTCLOUDCOLORMAP
- POINTCLOUDDEVIATION
- POINTCLOUDFITPLANAR
- POINTCLOUDPROJECTSECTION
- SIMPLIFY
The content of a command panel depends on the active command. It can be categorized into three domains:
- Necessary steps, for example:
- Entity selection
- (Base) point selection
- Naming
- Choosing alternatives
- Settings, for example:
- On/off options
- Default values
- Tolerances
- Command progress, for example:
- Number of handled elements versus total number of elements to process.
- Progress meter.
The command panel opens when the command starts and closes when the command ends.
