BCPARAMETER command
Adds constraint parameters or converts dimensional constraints to constraint parameters.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Adds constraint parameters to entities in a dynamic block definition based on the selected constraint points or converts dimensional constraints to constraint parameters.
Method
Open the Block Editor in the Dynamic edit mode. Launch the command and select a constraint parameter type.
Select the constraint points manually or click Entity to automatically use the start and end points of the selected entity as constraint points, then place the dimension line.
The added constraint parameters are displayed in the:
- Parameters Manager panel under Dimensional Constraint Parameters and in the Mechanical Browser, with the Block Editor open in the Dynamic edit mode.
- Properties panel under Custom, while the dynamic block is selected.
For a selected constraint parameter, you can set the values of the Value set and the Number of grips properties in the Properties panel as follows:
- Value set
- Limits the parameter's available values in the block reference to only those specified in the set.
- None
- Does not specify a value set.
- List
- Specifies a list of values available for the parameter.
- Increment
- Specifies a value increment and minimum and maximum values for the parameter.
- Number of grips
- 0
- No grips are displayed for the block reference. Instead, the selected geometry can be edited in the Properties panel.
- 1
- A grip is displayed at just the endpoint of the parameter.
- 2
- A grip is displayed at both the start point and endpoint of the parameter.
Options within the command
- Entity
- Uses the start and end points of the selected entity or segment as constraint points.
- Linear
Creates a horizontal or vertical constraint parameter, based on dimension line and extension line origin locations.
- Horizontal
Creates a horizontal (X distance) constraint parameter between two points on different entities.
- Vertical
Creates a vertical (Y distance) constraint parameter between two points on different entities.
- Aligned
Creates an aligned constraint parameter for the length of a line, the distance between lines, a point and a line, or between points on entities.
- ANgular
Creates angular constraint parameter between two lines or polyline segments, similar to an angular dimension.
- Radius
Creates a radius constraint parameter on a circle, arc, or polyline arc segment.
- Diameter
Creates a diameter constraint parameter on a circle, arc, or polyline arc segment.
- Convert
Converts the selected dimensional constraints to constraint parameters.
