BCONSTRUCTION command
Converts entities to construction geometry.
Icon:
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Converts selected geometric entities in a block to construction geometries during the BEDIT session.
Method
After you open a block for editing, select the geometric entities you want to convert to construction geometries.
Note:
  • This command is only available during the BEDIT session.
  • Construction geometries are displayed in dashed gray lines.
Options within the command
Convert
Converts selected geometric entities into construction geometries.
Revert
Reverts selected construction geometries into regular geometric entities.
Show all
Displays construction geometries in the current block editing session.
Hide all
Hides construction geometries in the current block editing session.
