BIMATTACHCOMPOSITION command
Attaches/detaches a BIM composition to solids.
BricsCAD BIM
Icon:
Method
The command:
  • Attaches a selected composition to selected solids.
  • Detaches compositions from the selected solids.
Note: To preview in the drawing the attached compositions, turn On the RENDERCOMPOSITIONMATERIAL system variable.
Select a composition and the solids to attach the composition to, then choose a reference face.
The command finds the broken connections (mitered/butted) between the selected solids and adjacent solids and automatically restores them.
Note: Make sure the KEEPCONNECTIONS system variable is turned On.
Accept/reject all restored connections or check connections individually.
There are three methods to select the composition to be attached to solids:
  • Enter the composition name.
  • Use the Compositions dialog box.
  • Select an entity with a composition attached.
Note: You can also drag an drop the composition from the Compositions panel.
Options within the command
Dialog
Opens the Compositions dialog box.
For more information about the dialog box, see the article BLCOMPOSITIONS command.
Entity
Applies the composition of an existing solid. First, select the entities to copy the composition from; next, select one or more entities to which to attach the composition.
deTach
Allows you to detach a composition, while keeping the BIM classification, as different from the Unclassify option of the BIMCLASSIFY command, which removes all BIM data.
Accept
Accepts all automatically restored wall-wall connections.
Reject
Rejects all automatically restored wall-wall connections.
Check individually
Zooms in the view to each restored connection and lets you accept/reject it.
Yes
Accepts the restored connection. Select Confirm.
No
Rejects the restored connection. Select Confirm.
Confirm
Confirms the previous option selection.
