BIMSECTIONOPEN command
Opens the drawing file related to a BIM section entity.
Icon:
Opens the drawing file related to a BIM Section entity, or the 3D BIM model related to a BIM section drawing.
Method
There are two methods to use BIMSECTIONOPEN command:
- Select a BIM Section entity in Model Space to open the generated BIM section drawing.
- Select a BIM Section result (a viewport) in Paper Space to open the corresponding 3D BIM model.
