BIMSTAIR command
Automatically creates a BIM staircase.
Icon:
Creates stairs between two floor slabs or any empty spaces using the distance between the Z- values of the selected start plane and end plane as the height.
Method
You can start creating a staircase by:
- Selecting a horizontal face of a solid.
- Selecting a void area.
The stairs display automatically when the cursor is moved. The type of stair being created depends on the position of the cursor with respect to the position of the selected start point.
The staircase is created as a parametric block with BIM properties. The component type is BIM Block(for more information about BIM Blocks, see the Using the Library panel article).
For all properties, parameters are created when creating the stair, driving the constraints of the parametric block. You can change these parameters individually afterward in the Parameters section of the Properties panel.
The Stair command panel opens, which allows you to easily change the settings before or while placing the staircase.
- Stair width
- Sets the stair width of the stairs.
- Head room
- Sets the minimal head clearance of the stairs.
The default value is 80 for MEASUREMENT=0 (inches), and 2000 for MEASUREMENT=1 (millimeters).
- Automatically flip/quarter-turn
- Toggles the stairs type.
- Preferred tread length
- Sets the preferred tread length of the stairs.
- Preferred riser height
- Sets the preferred riser height of the stairs.
- Step thickness
- Sets the thickness of the individual steps.
- Nosing
- Sets the horizontal distance of the overlap between subsequent treads.
- Final tread
- Controls the creation of a tread at the elevation of the top bounding slab.
- Final tread length
- Sets the length of the final tread.
The default value is 11.5 for MEASUREMENT=0 (inches), and 290 for MEASUREMENT=1 (millimeters).
- Landing extension up
- Sets the extension of the landings created with the BIMSTAIR command in the up direction. Default value is 0.
- Landing extension down
- Sets the extension of the landings created with the BIMSTAIR command in the down direction. The default value is 0.
Options within the command
- Quarter-turn
- Turns the direction of the stair cursor by 90 degrees.Note: Alternatively, you can press the Ctrl key once to turn the stair cursor by 90 degrees.
- Flip
- Turns the direction of the stair cursor by 180 degrees.Note: Alternatively, you can press the Ctrl key twice to turn the stair cursor by 180 degrees.
- U-shape type
- Switches between two different U-shape type stairs:
