BIMCURTAINWALL command
Creates a curtain wall.
Icon:
Creates a curtain wall, as a block, from the face of a 3D Solid.
Method
Select a face on a solid. A preview of the grid is displayed on the selected face.
Specify the grid's dimensions or the number of panels, specify the width, depth, glass thickness, or the connection type, or press Enter to accept the predefined values.
A BIM Block component (a block reference with BIM properties) of the Curtain Wall BIM entity type is created.
Important: BIM Blocks are compatible with BricsCAD® V26 and later. Drawings with BIM Blocks can be opened with older BricsCAD® versions. However, when inserting BIM Blocks in BricsCAD® V25 or older, they lose their BIM data.
Options within the command
- Length U panels
- Sets the length of the panels in U direction (height).
- Length V panels
- Sets the length of the panels in V direction (width).
- Number U panels
- Number of panels in U direction (rows).
- Number V panels
- Number of panels in V direction (columns).
- Width
- Defines the width of the curtain wall frame, mullions and transoms.
- Depth
- Defines the depth of the curtain wall frame, mullions and transoms.
- Glass thickness
- Defines the thickness of the glass panels.
- Connections type
- Defines the type of the connections between horizontal and vertical mullions.
- sTraight
- Creates a straight connection.
- Smooth
- Creates a smooth connection.
- Nodes
- Creates a node connection.
- Delete defining entities
- Whether the selected source entity is retained or deleted depends on the value of the DELOBJ system variable.
