Manage Routines dialog box
The Manage Routines dialog box allows you to manage the routines.
- Add routine
- Routines table
- Drop-down menu
- Edit routine
- Import routines...
Add routine
Adds a new empty routine under a default name (New Routine_1) that you can rename.
Routines table
Lists all saved routines and the number of tasks for each.
Right-click the table header to display a context menu that allows you to enable or disable columns, show all columns, or restore column positions.
Drop-down menu
Press the three dots button (
) to open a drop-down menu.
- Edit
- Opens the Edit Routine dialog box to edit the routine. See the related article Edit Routine dialog box.
- Rename
- Renames the routine.
- Duplicate
- Creates a duplicate of the routine.
- Export
- Opens the Export Routine dialog box to export the routine to a RTN file.
- Delete
- Removes the routine from the list.
Edit routine
Import routines...
Opens the Open dialog box to import a RTN file.
Note: You can duplicate, delete, export, and import multiple routines at once.
