Edit Routine dialog box
The Edit Routine dialog box allows you to define the tasks to be performed within a routine during the DWGHEALTH command.
- Routine name
- Tasks
- Add new
- Save
- Run
Routine name
Displays the name of the routine that is being edited.
Tasks
Lists the tasks selected for the routine to be performed during the DWGHEALTH command.
Add new
Adds new tasks to the routine from the drop-down list.
Save
Saves the routine.
Press the arrow from the right to open a drop-down list with two options for saving:
Save: saves the routine with the same name.
Save as: opens the Save Routine dialog box to save the routine with a different name.
Run
Allows you to run the edited routine under the New Routine* name, without saving it.
Note: The Drawing Health command context panel displays a Save as button after you run an unsaved routine via the Run button in the Create Routine dialog box/Edit Routine dialog box. Click it to open the Save Routine dialog box and save the custom routine with the desired name.
