INTERFERENCEMANAGERPANELCLOSE command (Experimental)
Closes the Interference Manager panel.
Disclaimer
The Interference Manager is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD.
Closes the Interference Manager panel to hide it from the current workspace. If the Interference Manager panel is stacked when you close it, the Interference Manager tab or icon is removed from the stack.
