SCANINTERFERENCES command (Experimental)
Identifies and manages interference between 3D solids or block references in complex 3D models.
Disclaimer
The SCANINTERFERENCES command is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
Method
Opens the Interference Manager panel if it was previously closed. See also the Interference Manager panel (Experimental) article.
Options within the command
- select Entities
 - Defines the selection set.
- between Two sets
 - Searches for interference between two distinct sets of entities.
- inside One set
 - Searches for interference inside a set of entities.
- SETtings
Calculates the clash volume.
- load Named study
 - Loads a previously saved scan.
- Run Scan
 - Runs the scanning.
