Interference Manager panel (Experimental)
Disclaimer
The Interference Manager panel is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD.
The Interference Manager panel allows you to identify and manage interference between 3D solids or block references in complex 3D models.
When the Experimental mode is enabled, the Interference Manager panel is active.
- Launch the INTERFERENCEMANAGERPANELOPEN command.
- Right-click a ribbon panel/toolbar and choose Interference Manager from the Panels list.
- Launch the SCANINTERFERENCES command.
To close the Interference Manager panel, launch the INTERFERENCEMANAGERPANELCLOSE command.
Press the New scan button to open the Configuration window that allows you to start scanning interferences.
- Home
- Selection
- Settings
Home
Restarts the interference scanning or opens the Home window that contains the saved scans.
- New scan
- List of saved scans
- New scan
- Opens the Configuration window to start a new scan.
- Lists the saved scans.
Selection
Defines the entities that will be searched for interferences.
- Inside one set of entities
- Searches for interference in a specific set of entities.
- Between two sets of entities
- Searches for interference between two distinct sets of entities.
- Selection set
- Defines the entity selection set.
Settings
- Calculate interference volume
- Toggles the option to calculate the volume of interference.
Results
- Save
- Highlight the interfering entities
- Update list
- List of the entities that interfere
- Save
- Saves the configuration and results of this scan. The Save interference scan dialog box opens.
Note: Saved scans can only be accessed during the current session and will be lost when the drawing is closed.
- Toggles the display of the interfering entities and the interference volumes in distinct colors, while the rest of the entities are transparent. Interfering entities are colored in cyan and yellow, while the interference volume is red.
- Update list
- Re-evaluates all outdated interference pairs in the result lists.
- Lists all interference pairs found between entities and displays the interference volumes.
The list is sortable by any of its columns. Easily navigate through interference pairs using the up and down keys. Select one or multiple rows to visualize their interferences simultaneously on the model.
While keeping the Results window open as a checklist, you can execute commands, such as DMPUSHPULL or MANIPULATE to resolve geometric interference.
- Status
- Displays the status of the interfering entities.
- Interference
- Entities are interfering.
- Outdated
- One of the interfering entities might be updated.
- Resolved
- Interference between entities has been resolved.
- Cannot be found
- One of the interfering entities cannot be found. It might be deleted or unloaded.
- Position
- Displays the position number of the pair of interfering entities.
- Entity 1
- Displays the first entity in the pair of interfering entities. It is colored cyan in the model.
- Entity 2
- Displays the second entity in the pair of interfering entities. It is colored yellow in the model.
- Volume
- Displays the value of the interference volume. The interference volume is colored red in the model.
