MVIEW command
Creates one or more viewports in Paper space (short for "make viewports") to display entities drawn in Model space. Each viewport can have its own settings, shown below.
Icon:
Alias: MV
Note:
  • This command operates only in Paper Space.
  • To create viewports in Model space, use the VPORTS command.
Specifies the first and the opposite corners to create a rectangular viewport.
Note: The viewports are created on the layer specified by the VIEWPORTLAYER system variable.
  1. First corner
  2. Opposite corner
  3. Viewport
  4. Viewport border
  5. Paper space (Layout)
Options within the command
ON
Turns on viewports that are turned off.
OFf
Turns off viewports.
This option hides the content of the viewport; the viewport border remains visible. To hide the viewport border, place it on a separate layer, and then freeze the layer.
Lock
Locks the viewport's scale factor.
Set the scale factor with the ZOOM command's nXP option.
Fit
Draws a rectangular viewport that fits the current layout.
create 2 viewports
Draws two rectangular viewports.
Horizontal
Draws two horizontal viewports of equal size.
Vertical
Draws two vertical viewports of equal size.
create 3 viewports
Draws three rectangular viewports.
Above
Draws one viewport above two side-by-side viewports.
Below
Draws one viewport below two side-by-side viewports.
Left
Draws one viewport to the left of two stacked viewports.
Right
Draws one viewport to the right of two stacked viewports.
create 4 viewports
Draws four rectangular viewports of equal size.
Entity
Converts an entity into a viewport border.
The viewport is traced over the entity; the original entity remains in the drawing. This option is useful for ensuring a viewport border precisely matches an outline.
Polygonal
Draws non-rectangular viewports made of lines and arcs.
draw Arcs
Enters arc drawing mode; options from ARC command are activated.
draw Lines
Enter line drawing mode; options from LINE command are activated.
Distance
Draws the next line segment at a specified distance and angle.
Follow
Draws the next line segment at the same angle.
