PARAMETRICMOVEEDIT command
Edits parametric move operations.
Alias: PMOVEEDIT
Method
The command lets you edit an existing move operation.
Enter the name of the desired move operation, then select the parametric operation data to be edited.
Options within the command
- Shownames
- Lists the names of all the move operations available in the drawing.
- Selection
- Lets you edit the elements selection of the specified operation.
- Direction
- Lets you define a new operation direction by selecting its base and second points of displacement.
- Linked behavior
- Allows you to decide whether the entities will follow operation definition points when adjusted by other operations.Note: The Linked property can also be turned On or Off from the bottom section of the Mechanical Browser. The On value is signaled in Parameters Manager and Mechanical Browser panels by the symbol ∞.
Note: When affected by a parametric stretch operation, linked parametric move operations behave differently from their unlinked variant.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
